Author Topic: Electric Window with its own mind  (Read 2965 times)
Offline IC
« on: 06 August 2003, 20:05 »
Anyone experienced this one? Every time I go around a corner sharply the front passenger window opens.
Offline seyles
Re:Electric Window with its own mind
« Reply #1 on: 07 August 2003, 10:10 »
Sounds like you have some loose wiring which shorts out due to the centrifugal force when cornering fast.
Check the connectors and the insulation on the wires/connectors that go to the switches, both sides. The switch could also be broken internally, causing the short.
Good luck
