Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403276 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... 007p revised piston rebuild
« Reply #590 on: 24 August 2013, 11:22 »
Just ordered a Pipercross foam cone filter for the Golf, the S2000 was just to see if I liked the noise etc lol
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #591 on: 20 September 2013, 14:02 »
Well it's goodbye to the R32 steering wheel... :cry:
Offline Rhyso
« Reply #592 on: 20 September 2013, 14:59 »
Why??  :huh:
Offline Diamond Hell
  • Opinions я Us
« Reply #593 on: 20 September 2013, 15:16 »
Because he owes Mike sexual favours of some description?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #594 on: 20 September 2013, 15:43 »
No sexual favours being exchanged, only cash and leather. Then again...
Offline Dave_IOW
Re: Wazzzer's 1.8T... Farewell R32 wheel... for now
« Reply #595 on: 23 September 2013, 23:06 »
I know your plans :lipsrsealed:
Tart :tongue:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #596 on: 25 September 2013, 21:09 »
shush you, all will be revealed shortly...
Decided to sort something that's been bugging me, my clocks.
I had a set of clocks modified by ray (aRd) a while back but recently two of the display SMDs started flickering then completely died :sad:
So I pulled them apart and had a good look over them at work to find it was a dry solder joint on one of the diodes. This was on the same circuit as the other causing them both to go out.
Hooked up to a power source
The offending diode
After a quick blast with the soldering iron
All is well again
Had a note through the door for attempted delivery today as well, I wonder what that could be... :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... Testing my soldering skills...
« Reply #597 on: 26 September 2013, 23:15 »
Some of you will know what this is from...
:afro:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #598 on: 02 October 2013, 22:20 »
My new steering wheel is finally in and... my phone battery ran out lol
Basically I've fitted a Mk5 R32/GTI flat bottomed steering wheel. A straight fit with the wheel but the airbag loom needing to be hybridized so the plugs fitted properly and the horn worked. A new steering wheel bolt was also bought as I'm pretty sure I've had it off six times now.
I've also replaced the steering wheel badge with a rabbit emblem as the VW logo was a bit scratched. I'm not sure if I'll keep the R badge on the bottom or change to a GTI version but I'll see. Oh and I've also ordered some brushed aluminium inserts to fit where the steering wheel controls normally fit. I've got black in there for now so we'll see what they look like.
Pics will follow tomorrow but for now I absolutely love the wheel :afro:
Best bit is it cost me nothing after the sale of my Mk4 R32 wheel :wink:
Offline Dave_IOW
Re: Wazzzer's 1.8T... return of the R32 steering wheel
« Reply #599 on: 02 October 2013, 23:29 »
Can confirm it looks good too :afro:
