Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403269 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Wazzzer's 1.8T... Wife button installed
« Reply #560 on: 02 June 2013, 10:51 »
Now that is sweet man...Real good work  :cool:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #561 on: 02 June 2013, 10:57 »
Cheers mate. It will also be good for long journeys to keep the fuel economy up
Offline Rhyso
« Reply #562 on: 02 June 2013, 18:19 »
Top work as always Wes  :smiley:
Offline dom
  • Back in a Mk4
Re: Wazzzer's 1.8T... It's pay day...
« Reply #563 on: 02 June 2013, 20:02 »
Replaced the one way valve in my WMI kit with a electrical solenoid this week and also wired up my wife button. It basically cuts the feed to the N75 valve leaving the car with around 8psi instead of 21...
That is a great idea! Easy enough to do?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #564 on: 02 June 2013, 20:16 »
Yeah just literally run the two wires from the switch out through the bulkhead then cut into one of the N75 wires so it's routed to the switch and you're done
Offline Chris#101
« Reply #565 on: 02 June 2013, 20:16 »
Love the cut off switch  :cool: any chance of throwing together a basic wiring diagram for it ? :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #566 on: 02 June 2013, 20:17 »
Aye will mock one up for you
Offline brett
« Reply #567 on: 02 June 2013, 20:20 »
Top work mate,subtle as  :cool:
Offline jonrandom
« Reply #568 on: 02 June 2013, 21:17 »
Good idea and nicely done mate  :cool:
jamie16v
« Reply #569 on: 02 June 2013, 21:43 »
great idea, but doesnt it throw up any codes?
