Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403831 times)
jockgti
Re: Wazzzer's 1.8T... carbon canister deleted, centre bumper vent in
« Reply #210 on: 20 February 2012, 21:28 »
no pm mate?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #211 on: 20 February 2012, 22:03 »
there is now sorry, forgot to send it  :laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #212 on: 24 February 2012, 21:09 »
got myself some matt black vinyl from ebay for a couple of quid and have just covered the visible intercooler pipe with it, worked a treat  :cool:
Will be fitting it back on tomorrow and also seeing if I can shove the intercooler back a bit if I cut some of the front panel away  :smiley:
Realised I don't have any pics of the plate welded on the MAP sensor boss so took one while the pipe is in front of me
Hopefully have it back on tomorrow
« Last Edit: 24 February 2012, 21:44 by Wazzzer »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... wrapped intercooler pipe
« Reply #213 on: 27 February 2012, 19:31 »
Pipe is back on and looks loads better
I managed to cut away a bit of the front panel and gave the intercooler a good shove backwards, probably only gained 5mm but it's enough to get the grille on properly
Speaking of which I've trimmed up the grille as well but I left my camera at work so no pics as yet.
Offline Scott D
« Reply #214 on: 27 February 2012, 20:09 »
a lot better black and will barely be noticeable once the grill is
does look a good clean fit that too
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #215 on: 27 February 2012, 20:19 »
Cheers mate. Yeah it's a good fit, well worth paying the extra over the eBay coolers if you want to keep it looking standard IMO. It looks a bit rough near the pipe but none of that will be visible once the grille is in. Just test fitted it and it's spot on now, will get a pic in the morning  :cool:
« Reply #216 on: 27 February 2012, 20:31 »
Looks loads better with the pipe black.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #217 on: 27 February 2012, 20:35 »
cheers mate, best bit is it only cost £4 delivered for the vinyl and about 20 mins of my time :afro:
« Reply #218 on: 27 February 2012, 20:38 »
Cheap mods / fixes are always the best ones.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #219 on: 27 February 2012, 20:41 »
I was thinking about spraying it first but with this stuff being so cheap now and so easy to fit it was a no brainer. It won't flake off either  :wink:
