Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403149 times)
Re: Wazzzer's 1.8T... black headlining complete
« Reply #160 on: 14 September 2011, 16:43 »
Headlining looks really good.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #161 on: 11 October 2011, 20:55 »
Cheers for the comments. Update time...
Bought some C20LET yellow injectors for the next time I visit R-Tech, and also a refurb kit for them which is fitted along with a nice ultrasonic clean
I was given a VR6 MAF housing by my mate which will be fitted with the injectors. I bought Patch's ABD FMIC from him and will be fitting it soon, just need to modify a few bits and get some new silicone pipe joiners in black as I'm a tart lol
I've also borrowed Dave_IOW's spare bumper to see what I need to trim to make it fit.
Will update once the FMIC has been fitted  :smiley:
Offline Dave_IOW
Re: Wazzzer's 1.8T... ABD FMIC is here
« Reply #162 on: 11 October 2011, 22:19 »
Good luck bud, hope you dont lose too much of your bumper  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #163 on: 12 October 2011, 18:29 »
I know what you mean mate but I should be able to get it to run round the back of it ok as Patch has cut the pipe just before the bend to lift it up a bit. Ideally I'd like an inlet manifold that has the throttle body on the other side... only thing stopping me doing this would be finding a suitable throttle cable  :wink:
Offline Diamond Hell
  • Opinions я Us
« Reply #164 on: 13 October 2011, 13:02 »
This has my clique detector twitching.  :grin:
Offline Dave_IOW
« Reply #165 on: 13 October 2011, 18:16 »
:laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #166 on: 20 November 2011, 10:43 »
ABD cooler was going to take too much work to make fit so it's been sold again and a THS intercooler bought to replace it
it needs a small bit of modifying to fit so I took the crash bar off and drilled the spot welds out to enable a metal plate to be removed
The metal that needs removing
and out after a bit of beating with a hammer and chisel
the intercooler hanger bolted on
Will get a pic of it on the car as it is now in a bit. I've used Dave's spare bumper as mine needs trimming and I haven't had the time yet
I've got hold of a spare airbox lid thanks to daz_veedub so that can be modified to accept the VR6 MAF housing so I won't lose the use of my current one. I should also have a manual boost controller here soon to help with the next stage of tuning.
I've also decided to fit a set of oil temp/pressure gauges just to monitor what's going on. I've bought a dual pod for the A pillar and will be using these gauges
http://www.ebay.co.uk/itm/230678615498?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
the pod will be trimmed in the same material as I used to cover the headlining
http://www.ebay.co.uk/itm/150687402297?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Wayne has kindly supplied me with everything I need to get the gauges plumbed in so this should be happening as soon as the gauges are here and I trim up the pod
Offline Dave_IOW
Re: Wazzzer's 1.8T... THS FMIC is here and fitted
« Reply #167 on: 20 November 2011, 12:20 »
Good progress bud, the only thing i dont like about the THS intercooler is when fitted to standard bumper, it doesnt look symetrical  :sad:
Small point i know, but gets me lol  sorta like...
   ___________
 |___________/
Sure you know what i mean  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #168 on: 20 November 2011, 12:39 »
You mean like this?
Offline Toby
  • Car - less
« Reply #169 on: 20 November 2011, 12:41 »
i see what dave's saying  :undecided:
but tbh, if it was sprayed black! and once the vents are in you wont really notice?
looks bang tidy thou wazza!!  :cool:
Currently down under
