Author Topic: damaged front jack point  (Read 1559 times)
Offline robson78
« on: 02 December 2004, 21:27 »
recently fitted koni t/a and eibach springs? :grin: tried to use standard jack other day? to do a job & it just slid away. A closer look shows that at the jacking point front ,the seams have been deformed so that the clawed foot on the jack doesnt fit on the seams that come together .
When the springs and shocks were fitted? i used a trolley jack with a protecter then axle stands further under car,since being fitted had service at specialist and had camber tracking & new tryes a/r its not worth trying to see if they`d except liability,they`ll only deny they did it .
Has? any one had a similar problem and had it fixed how much ? Ive tried to? look at doing it but now the car is lower theres no room unless you got a pit.
Mk3 16V Eibach pro kit springs with lowering caps so its only dropped 40mm.before a trip to body shop any ideas,before a puncture? :huh:
mowgli
Re: damaged front jack point
« Reply #1 on: 10 December 2004, 11:47 »
I had the same problem on my 3rd gti, a local bodyshop sorted it out for about ?40 IIRC.
Offline robson78
« Reply #2 on: 21 December 2004, 21:08 »
cheers for the reply time off at crimbo to get it fixed
