Author Topic: RCD 210 Display Problem  (Read 1119 times)
Offline Makaveli
« on: 03 May 2010, 09:19 »
My Mum has a Golf MKV with an RCD 210 radio - the problem is that when you take the key out of the ignition after using it the blue display light won't come back on when you start the car again (with the lights on).  It didn't used to do this and it is very annoying having to set the display light each time you switch the lights on.
Has anyone had this fault before and been able to fix it?
