Cosmetic and bodywork matters
SWITCH LIGHTING CHANGING THE LEDS?
Topic: SWITCH LIGHTING CHANGING THE LEDS? (Read 2502 times)
damien010685
03 May 2010, 00:18 »
Hi guys probably like my tenth post on this but im useless with this crap.... With regards to leds inside the switches ie rear heated window switch and electric window switches i have been told that if i use a 3mm 12v led this will be ok can somone clarify this? And if so will these ones work as my understanding is all i need t d is cut the origional Led and solder the blue or whatever 1 on?
http://www.maplin.co.uk/module.aspx?TabID=1&criteria=usb&ModuleNo=35738&C=SO&U=Strat15
Or These
http://www1.conrad-uk.com/scripts/wgate/zcop_uk/~flN0YXRlPTM5NDgzNjQwNTE=?~template=PCAT_AREA_S_BROWSE&glb_user_js=Y&shop=UK&zhmmh_lfo=&zhmmh_area_kz=&product_show_id=182425&gvlon=&p_init_ipc=X&p_page_to_display=fromoutside&~cookies=1&cookie_n
[1]=uk_insert&cookie_v[1]=8V&cookie_d[1]=&cookie_p[1]=%2f&cookie_e[1]=Thu%2c+03-Jun-2010+20%3a20%3a02+GMT&scrwidth=1280
I appreciate all your help lads one day il manage to answer a question haha Cheers
sharki786
GOT BOOST??
Re: SWITCH LIGHTING CHANGING THE LEDS?
03 May 2010, 21:10 »
if for the mk3 then yes, how bright do you want them to be? also they may pop even if they are 12v as it happened to me then i used a resistor and it worked for me. the higher the Luminous Intensity the more brighter the light will be. what colour are you after?
try this website:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=retrieveTfg&binCount=359&Ne=4294957561&Ntt=3mm+led&Ntk=I18NAll&Nr=AND%28avl%3Auk%2CsearchDiscon_uk%3AN%29&Ntx=mode%2Bmatchallpartial&N=4294955205&Nty=1
they have quite a few colours but on some you will need a 12v resistor. its all about trial and error
Last Edit: 03 May 2010, 21:14 by sharki786
*****MK3 Anniversary*****
*****MK4 GTI T*****
sharki786
GOT BOOST??
03 May 2010, 21:19 »
heres a kinda start,
http://www.golfgtiforum.co.uk/index.php?topic=71211.0
http://www.dubdesignindustries.com/catalog/download-ddi.php
, dif types of led mods.
http://www.golfgtiforum.co.uk/index.php?topic=71541.0
hope that helps you
*****MK4 GTI T*****
damien010685
04 May 2010, 00:20 »
Yeh thx mate
gonna try myself but will defo need kells to hook me up with my speedos lol
sharki786
GOT BOOST??
06 May 2010, 18:15 »
yes best to, but i didnt mine and it wasnt so hard you know. but the two LCD's i aint done yet. good luck mate
*****MK4 GTI T*****
kells
Guest
06 May 2010, 20:45 »
you know where im at dude
sharki786
GOT BOOST??
Reply #6 on:
08 May 2010, 14:15 »
sorry i 4got to mention you kells! :embarassed:
*****MK4 GTI T*****
