Author Topic: Renault Scenic clay, polish and wax - and questions..  (Read 2421 times)
Offline javalin
Hey all,
First chance to use my new G220 Megs oribital polisher...
http://javalins.wordpress.com/2010/05/01/renault-scenic-clay-polish-wax
Paint didn't come up as well as the Ford Fusion I did a few weeks ago.  :sad:  Both the same year, but very different lives.  Which I wonder is just the poor general condition of the paint. The bonnet went all patchy.  Something I did or just the paint?  Here - http://javalins.files.wordpress.com/2010/05/scenic_shinybonnet.jpg
Back of the wheels was solid with ingrainded brake dust / etc - how to clean it? Plenty of megs wheel cleaner and elbow grease applied, more elbow grease required?  Here - http://javalins.files.wordpress.com/2010/05/scenic_still_dirty_backofwheel.jpg
Finally - can you get a 5L of decent wheel cleaner - almost used a whole bottle of megs on these!
Knackered now.
Cheers all,
James
« Last Edit: 01 May 2010, 21:10 by javalin »
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Dan J
Re: Renault Scenic clay, polish and wax - and questions..
« Reply #1 on: 01 May 2010, 23:39 »
for the whells try some neat tfr or some diluted whell acid, should shift all that better than APC because APC is better at de-greasing and general cleaning, TFR will attack the crusty backed on break dust/road grime, after you've got them how you want them give them a really good rinse off then wash with some soapy water well and rinse again, dry off and give them a good polish by hand then seal and wax them, they'll stay cleaner for longer and the sealant and wax will stop contaminents bonding to the surface.
Offline javalin
Offline javalin
« Reply #3 on: 02 May 2010, 20:43 »
Might have figured out what I did wrong with the bonnet.  I think the polish dried then I didn't wipe off enough before waxing.
Doh.  But easily correctable.
Oh, can anybody recommend a more aggresive clay?  I.e. for doing the bottom of the door panels where contamination is particularly bad...?
James
Offline Dan J
« Reply #4 on: 03 May 2010, 01:56 »
this is a slighly more agressive clay, import to use lots of clay lube with this one :wink:
http://www.waxamomo.co.uk/productcart/pc/viewPrd.asp?idproduct=202&idcategory=4
awesome clay:
http://www.waxamomo.co.uk/productcart/pc/viewPrd.asp?idproduct=199&idcategory=4
dont forget your forum discount when you order :wink:
Offline javalin
« Reply #5 on: 03 May 2010, 10:26 »
thanks again Dan.
