Author Topic: Group Buy for OEM Mk6 LED Tail Lights - Round Two  (Read 40674 times)
Offline dave7268
Re: Group Buy for OEM Mk6 LED Tail Lights - Round Two
« Reply #170 on: 15 July 2010, 21:00 »
Thanks Mike.
Just set it to 04 again and the lights are now working again but I still have the bulb out warning lights and error codes in VCDS. Also now get a message from the MFD telling me to check rear fog light as bulb is out and now the rear fog is not working  :sad:
To top it all it has now started to chuck it down so I'm afraid rain has stop play until tomorrow. Any other suggestions/remedies most appreciated.
Steve - I will try a reset as you describe tomorrow after I get home from work to see if that helps with the fog light.
The error codes were telling me that I had bulbs out in all the rear clusters.
7GTI PP DSG - no longer
Offline SteveP
« Reply #171 on: 15 July 2010, 21:11 »
When you first plug them in VCDS will show error codes on all parts of the lights, if you clear these codes what errors are you left with?
Offline dave7268
« Reply #172 on: 15 July 2010, 21:33 »
Aha, I will get back to you tomorrow with what errors remain after clearing the codes. Cheers Steve
« Reply #173 on: 16 July 2010, 06:06 »
So I'm not the only one with a few ECU vs rear LED issues then?  :cry:
Still got to take my hat off to Steve and Dave for arranging the group buys brilliantly and a special thanks to Dave for his patience and persistance with my ghost fog light.
Offline SteveP
« Reply #174 on: 16 July 2010, 07:47 »
I have a set of lights from the same batch as both of yours here so I am going to test these today just to make sure it's nothing related to them.
Dave7268 - Please can you do a full autoscan with VCDS and send me the text file (steve at mk5golfgti dot co dot uk)
Offline SteveP
« Reply #175 on: 16 July 2010, 07:50 »
Also Dave, which version of VCDS did you use?
Offline countrytrucker
« Reply #176 on: 16 July 2010, 09:06 »
If I install the light units without getting the coding done for a day or 2, will this mess anything up or will I just have 'bulb out' warnings?
I read that the computer can cut the power to certain lights if it thinks they are blown so I wouldn't fancy driving tonight with no lights  :sad:
I love my GTD
Offline dave7268
« Reply #177 on: 16 July 2010, 17:09 »
Steve, I have sent you an email.
For the record, the reset has fixed the lights not working issue and I have set byte 18 to 04 again and everything appears to be working okay apart from the error codes which I can't get rid off and my mfd is telling me to check the rear right fog light. Bulb out warning light is still present on the dash.
Offline SteveP
« Reply #178 on: 16 July 2010, 17:14 »
Hi Dave,
Got your email and have replied.
Being 100% honest it's looking like there is an early batch of Mk6's with a BCM (central Electrics controller) that is not able to support the LED's properly.
If this is the case then I will, of course, offer a full refund.
If your able to meet me tomorrow (as per the details in the email) then I will be able to confirm this  :cry:
Cheers,
SteveP
Offline gizzywizzy
« Reply #179 on: 16 July 2010, 17:22 »
Hi Dave,
Cheers,
SteveP
Oo err
Darren is finally fitting my LEDs and RNS510 on Sunday, my car is from July 2009, do you think I may have this problem too?
Gizzy
