Author Topic: Where does this green and red wire connect too???  (Read 1501 times)
Offline walchy01
« on: 28 April 2010, 17:05 »
Can anyone tell me where this should plug into please???
thanks
Offline walchy01
Re: Where does this green and red wire connect too???
« Reply #1 on: 28 April 2010, 19:34 »
Anyone electrically minded??? Can u help???
Offline jezza16v
« Reply #2 on: 28 April 2010, 19:46 »
Well you don't say what year or type your car is? Mine is a 91 8v and the only green and red wire I can find goes to the windscreen washer motor but it has a twin plug with another wire. The only wire with a plug like that that I can find is red and black on mine and goes on to a spade on the end of the starter motor.  :undecided:
Offline walchy01
« Reply #3 on: 28 April 2010, 19:57 »
Sorry, it is a 16v 1991 h plate, I did the starter motor after xmas but still can't see anything missing off there. :angry:
« Reply #4 on: 29 April 2010, 09:33 »
any one of the 3 small single pin black sensors on the side of the head, that wire is for the isv control unit
Offline walchy01
« Reply #5 on: 29 April 2010, 14:47 »
Thanks for that, u haven't got a photo of where it goes exactly do you???
Thank you :wink:
« Reply #6 on: 29 April 2010, 15:50 »
not to hand, but look on the side of the head for a big plastic flange with a rubber coolant hose on it. around this are 3 small single pin sensors, and a large 2 pin connector.  one of the single pin sensors will be missing a wire.
hopefully the terminal end hasnt snapped off and you can just plug it back in
Offline walchy01
« Reply #7 on: 29 April 2010, 16:30 »
Thank you, I will have a look once it stops raining :angry:
