Author Topic: Spark plugs, leads and fuel filter  (Read 1265 times)
Offline tuscan_thunder
« on: 28 April 2010, 11:51 »
Straightforward:  what's the best plugs and leads?  OEM?
Fuel filter: is it an easy change?
thanks in advance
Offline Hurdy
Re: Spark plugs, leads and fuel filter
« Reply #1 on: 28 April 2010, 11:55 »
What mods have you got?
Generally speaking if you are a GTI or ED30 without a map or stage 1, then simply use OEM Bosch plugs.
If you are stage 2 or 2+ then either Denso Iridium IK24 or NGK Iridiums. These are "cooler" plugs than OEM and help reduce the possibility of detonation and overheating. :smiley:
Seat Leon Cupra Black 290 DSG
« Reply #2 on: 28 April 2010, 16:20 »
Absolutely standard but at 45k I'm pretty sure they'll never have been changed.  OEM it is.
Fuel filter anyone?
Offline Hurdy
« Reply #3 on: 30 April 2010, 00:20 »
Fuel filter is relatively easy.
It is located on the right-side of the car just in front of the fuel tank.
Just remember to fit it facing in the right direction :laugh:
