Author Topic: G60 gearbox 5th gear swap...  (Read 2536 times)
Offline LazyLunatic
  • MK3 20VT Project
« on: 28 April 2010, 11:44 »
I was wondering what my options are here. I currently have the G60 02A gearbox and the ratios are very short. Cruising along at 70mph means the engine is around 3500rpm, then up to 4000rpm at 80mph. This is 5th gear.
I heard that a 5th gear from a TDi can be used or a 6th gear from another VAG gearbox....
I also heard you can leave the box in and do it....
Can anyone shed some light on this, would nice to have a 5th gear to cruise in.
VeeDubGTI16v
Re: G60 gearbox 5th gear swap...
« Reply #1 on: 28 April 2010, 20:06 »
are you sure its a g60 box? the one on mine has a long 5th, its 1st and 2nd that are too short  :laugh:
ill have to double check but 80 is deffo under 3500rpm.
you are probably better off choosing another 02a box and using that instead of rebuilding, less hassle and cheaper!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2 on: 03 May 2010, 16:28 »
i heard you can do it with the box in.... i thought it was a little more common :D
Offline raferackstraw
« Reply #3 on: 03 May 2010, 20:55 »
have a look on here gives all the info you need
http://www.brokevw.com/5thswap2.html
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
« Reply #4 on: 04 May 2010, 10:44 »
unfortunaly g60 box is cable shift which is completly different to 020, so brokes site is no help here
Offline LazyLunatic
  • MK3 20VT Project
« Reply #5 on: 04 May 2010, 11:48 »
thanks and thanks. anyone know details on how this can be done. i dont fancy trail and error on this one :D
VeeDubGTI16v
« Reply #6 on: 04 May 2010, 12:33 »
you really want to strip a box down rather than swap it?
http://www.clubgti.com/forum/showthread.php?t=115595
ratios are there^
put them into a gear calculator to work out in gear speeds and chose a better box
Offline Paul86S2
« Reply #7 on: 04 May 2010, 19:01 »
Offline Cartman
« Reply #8 on: 04 May 2010, 22:11 »
I have a g60 in a Mk3 with gearbox from passat with 9A engineand  it is very short, too.
I am planning to put a gearbox from GTI 16v mk3, I heard that it has a bit longer gears
