Author Topic: struts and ring spanners  (Read 2425 times)
Offline Cory
« on: 28 April 2010, 08:15 »
hi just a quicky,
need to replace the top bearing on the suspension as mines worn and knocking (so im told by the servicing man)
so was just wondering if the bolt on the top of the stut is a standard size? and if anyone knows it, as im gunna
have to get hold of a ring spanner, hoping i can borrow one from uni
many thanks
cory
« Last Edit: 28 April 2010, 08:36 by Cory »
Re: struts and ring spanners
« Reply #1 on: 28 April 2010, 09:57 »
If its the original nut it'll be 21mm, which is the same size as a large sparkplug socket. these also have spanner flats on so you can drop an allen key down the middle. if the nuts have been replaced they'll be 22mm, which is the same size as a lambda probe/diesel injector socket. these also have spanner flats on, and often have a slot cut into the side where you can get your allen key in.
You may struggle to fget the nuts off if they have been buzzed on by a garage though, worst case pop to a local garage and ask em nicely to buzz em loose then do up finger tight, then drive home and swap the suspension over
Offline weazgti
« Reply #2 on: 28 April 2010, 18:47 »
I normally have to borrow a swan neck spanner because i dont have any and the nut is slightly recessed so a normal spanner doesnt fit.
Didnt think of using a spark plug socket, i forgot they have a bit to get a spanner on.
Offline Steve_B
« Reply #3 on: 28 April 2010, 19:05 »
This is what i used, put the VW wheel bolt wrench around the allen key to use as an extension
Offline richard s
« Reply #4 on: 28 April 2010, 20:16 »
i have a cheap deep socket with a nut welded on top
Offline Cory
« Reply #5 on: 28 April 2010, 21:52 »
ahhhh, thats awesome help!
thanks guys  :smiley:
« Reply #6 on: 29 April 2010, 09:35 »
if its a 7mm allen key you need, I found the perfect tool in halfords. randome 7mm allen with a big soft handle on, apparently its for ford brakes or summat
Offline Cory
« Reply #7 on: 29 April 2010, 10:33 »
ahh  cheers buddy, may pop down and have a looky in halfords later on =)
Offline JimR
« Reply #8 on: 29 April 2010, 13:36 »
This. I had to buy on to undo the calliper slide bolts on my sisters mk3 astra, perfect for suspension strut.
Mk2 GTi.
Offline Cory
« Reply #9 on: 29 April 2010, 16:51 »
had a little looky in halfords earlier and couldnt find it, could someone possibly post a link to it on
their website?
