Author Topic: How much coolent  (Read 1653 times)
Offline Deefadog
  • Mk2 16V (November 89)
How much coolent
« on: 29 November 2004, 13:31 »
Stupid one i know but, how much coolant do i add? I have drain the system completely and want to refill it, Haynes says it take 6.3 liters! How much of this should be coolant?
Offline jv
  • Administrator
Re: How much coolent
« Reply #1 on: 29 November 2004, 13:34 »
think the guide is 50% in winter, could be wrong....
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Gambit
« Reply #2 on: 29 November 2004, 13:38 »
i just put in about 2ltrs of the stuff
the higher the concentration of anti-freeze the hotter your car will run.
make sure your car a good flush out first off. drain then fill it with just water and run the car till it boils in the expansion bottle. then drain all that off and then refill with anti-freeze & water
make sure your heater is set to max heat when draining/filling!!
Offline Deefadog
« Reply #3 on: 29 November 2004, 14:27 »
Cheers, will do!
Blue MK2
« Reply #4 on: 29 November 2004, 14:29 »
check out the rusty water while your at it  :grin:
Offline Deefadog
« Reply #5 on: 29 November 2004, 14:32 »
It has been drained and refilled twice in the last 3 weeks - due to oil cooler removale and a leak, water was very good! not much rust at all!
