Author Topic: error code?  (Read 1835 times)
Offline paul7278
  • boom boom problem solved!
error code?
« on: 25 April 2010, 16:37 »
my 8v is still running badly i.e hesitating when lifting off the throttle  :sad:. i plugge din bosch kts and it came up with this error code? anybody have any idea and where is the icv?
VW BUSH
Re: error code?
« Reply #1 on: 25 April 2010, 17:05 »
What engine you got?
I had same sort of issues with ADY tuther week not the same code though but R Johnny put me onto throttle body calibration and it did the trick. (Thanks RJ)
Was confusing me because ADY does not have ISV and all other bits involved tested fine
I will try and find the post...........
VW BUSH
Offline paul7278
Re: error code?
« Reply #3 on: 25 April 2010, 17:20 »
mines a 8v 2.0 gti mate. just so annoying when you lift off the throttle it jerks/ hesitates. :cry:
Offline paul7278
Re: error code?
« Reply #4 on: 25 April 2010, 23:52 »
does the agg have a idle valve?
VW BUSH
Re: error code?
« Reply #5 on: 26 April 2010, 00:38 »
Nope 2E and ABF have an ISV, ADY/AGG have a different set up.
Have you done the T body and relays thing yet..... :smiley:
Offline paul7278
Re: error code?
« Reply #6 on: 26 April 2010, 00:50 »
cleaned the tb whats the relay thing? :undecided:
Offline axewielder
  • 95 dragon 8v
Re: error code?
« Reply #7 on: 26 April 2010, 10:02 »
ecu+ fuel pump relay, do a search for more info. I would try cleaning the TB thoroughly on both sides, especially around where the butterfly closes. disconnect battery for 1/2 hour to reset ecu so that the TB can re align itself, clear error codes + try again.
Offline mark-mk3gti
Re: error code?
« Reply #8 on: 26 April 2010, 11:23 »
mine does this aswell 2.0 8v agg and I had taken off throttlebody and cleaned, also fuel pump relay fitted,  but didn't align tb, should I? From previous post looks like I need to disconnect bat for a bit then when I reconnect will it align it's self? Can u hear it doing it? Cheers
Offline axewielder
  • 95 dragon 8v
Re: error code?
« Reply #9 on: 26 April 2010, 11:49 »
yeh disconnect battery for around 1/2 hour +when reconnected + ignition on but eninge not started should reset+ make a whiring sort of sound, have read that for the impatient ppl, you can bridge the +ve and -ve terminals to drain the remaining charge in the ecu, obviously be careful+ dont short across the battery terminals as this will likely do some damage to a component or to you.
