Author Topic: Ignition Timing on MK2 K-Jet 8v + MK3 2.0 bottom end  (Read 3316 times)
Offline oldmiller8
Just after a wee bit o' advice.
I have a MK2 Golf GTi 8v, It has a 2.0L bottom end from a MK3 (not sure which engine code, but can find out) and a 1.8 K-Jet head.
Just set timing up dead on with marks on gearbox, marks on crankshaft pulley are also showing dead on. The car runs like crap ie, well under powered. I have just retarded the timing, roughly about 6-8 degrees and power has returned but pinking slightly.
Just wondering if anyone knows what the timing should be set at?
Offline Horney
Re: Ignition Timing on MK2 K-Jet 8v + MK3 2.0 bottom end
« Reply #1 on: 25 April 2010, 16:26 »
6 BTDC.
nick
Offline oldmiller8
« Reply #2 on: 25 April 2010, 21:51 »
Noooice one!  :smiley:
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 28 April 2010, 20:38 »
£10 says the K-sh*t is running lean which is why it's pinking
 :rolleyes:
« Last Edit: 28 April 2010, 20:42 by Diamond Hell »
Offline raferackstraw
« Reply #4 on: 30 April 2010, 12:32 »
as dh says running lean but you also need to use 98ron if i use 95 on mine it pinks when engine is very hot
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
