Author Topic: scary breaks  (Read 1659 times)
Offline terry221984
scary breaks
« on: 25 April 2010, 12:29 »
was driving around yesterday and when approaching a junction put foot on break as normal not hard but the car nearly locked up luckily no one was close behind, the car drove normally all the way home but this morning went on a short drive and suddenly the breaks started making that grinding abs noise and when i touched them there was alot of resistance in the peddle and they nearly locked up again?????? obviously abs but what ??? any ideas thankyouplease!!! :smiley:
Offline VR6-Joe
Re: scary breaks
« Reply #1 on: 25 April 2010, 12:39 »
*Brakes
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline terry221984
Re: scary breaks
« Reply #2 on: 25 April 2010, 13:02 »
*thanks
Offline christomk3gti
Re: scary breaks
« Reply #3 on: 25 April 2010, 13:02 »
straight to the point as usual joe  :grin:  :grin:
Get them checked out. For your/other peoples safety.
Black 8v GTI............. Whats a Waffle Valve?
Re: scary breaks
« Reply #4 on: 25 April 2010, 15:53 »
+1 not something to mess around with really.
Offline AudiA8Quattro
Re: scary breaks
« Reply #5 on: 25 April 2010, 16:05 »
Is the ABS light on?
Could be a faulty control unit/pump. Plug the car into VAG-com.
Offline shaunmk2gti
  • My V dub
Re: scary breaks
« Reply #6 on: 25 April 2010, 18:23 »
Mine also does this from time to time so let me know if you find the problem or if i do i will do the same.
Offline richard157
Re: scary breaks
« Reply #7 on: 25 April 2010, 20:31 »
My 16v started doing this about 6 months ago,traced it to the o/s/r abs sensor when i replaced the wheel bearing.I found the sensor had split and corroded from the inside.Braking was scary and unpredictable so ive unplugged the abs unit under the bonnet and braking is ok now-obviously no abs,but no heart stopping moments in traffic that suddenly stops :laugh:.Not a fix but will keep you on the road until you get it sorted.
Offline terry221984
Re: scary breaks
« Reply #8 on: 25 April 2010, 20:34 »
cheers for the help all where exactly do you unplug the abs??? going to plug it in t laptop tommorrow anyhoo so will let you know what if anyting i find :smiley:
