Author Topic: Car just died "operation too low P0420"  (Read 2362 times)
Offline 1.6mk4GOLF16v
« on: 24 April 2010, 08:37 »
Started perfect, about to take off n i hear a chewing kinda noise like something was hitting/cracking under the car
Seconds later it stopped and didnt start again, turns over fine like she wants to start but never did
Got the AA to tow it home n did a quick scan on his SnapOn kit
Code that came up was:
Cylinder bank 1 efficiency 16804
Operation too low P0420
She has had a de-cat job done so i usually have the engine management light on anyway, with the "Cylinder bank" fault code but i do, do regular scans, its the secong half of the fault (P0420) that ive never seen before
Any suggestions where to start guys? gonna do a quick search on the forum now
« Last Edit: 24 April 2010, 09:31 by richw911 »
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline topher
  • Administrator
  • fully functioning
Re: Car just died "operation too low P0420"
« Reply #1 on: 24 April 2010, 10:02 »
16804 and P0420 are the same code, just one is manufacturer specific and one is obd generic.
« Reply #2 on: 24 April 2010, 10:33 »
The AA guy who picked it up said it could be the sensor near the crankshaft, mean anything to you?
With the codes that ive put what would you suggest where i start mate?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #3 on: 25 April 2010, 19:28 »
Anyone?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline MK3TDi1996
« Reply #4 on: 25 April 2010, 19:40 »
The crank sensor.  I'm a mk3 man myself but it's the same thing really.
Just a little sensor to tell the ecu where the crank rotation is at.  It will indeed prevent it from starting aye.  Check your wiring to it and if it all seems well then unbolt the sensor from the block and see if it is covered in sh*t (clean if so) or seek out a replacement sensor...
« Reply #5 on: 27 November 2010, 05:57 »
turned out the timing belt broke (ouch) couple of valves bent aswell!  :embarassed:
£600 to sort the valves and skim the head etc and have it working perfectly
VW garage quoted £1295  :shocked:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
