Author Topic: RNS510 Voice guidance volume?  (Read 9491 times)
Offline p3eps
« on: 23 April 2010, 19:14 »
Can anyone tell me where I can adjust the volume of the lady who tells me where to go?!
I could barely hear her before, and now for some reason she doesn't speak at all  :sad:
I've been into the Setup -> Nav menu... and voice guidance is ON.
Anyone?!  Its probably really simple, but having an eBay unit - I have no manual to check  :rolleyes:
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline p3asa
Re: RNS510 Voice guidance volume?
« Reply #1 on: 23 April 2010, 19:14 »
When she talks adjust the volume to what you want it to be.
Offline p3eps
« Reply #2 on: 23 April 2010, 19:51 »
So I just wait until I think she should be speaking, and twist the volume up?!
Its a bit tricky since I can't hear her - but I guess I could press the button that makes her repeat the last instruction and turn it up then?
Offline p3asa
« Reply #3 on: 23 April 2010, 20:08 »
Basically yes that's it.
Set some directions and then turn the volume up when you ask her to repeat herself.
http://www.mk5golfgti.co.uk/forum/index.php?topic=12450.0
Manual here:
http://www.enderelektronik.com.tr/RNS510_Manual.pdf
Offline p3eps
« Reply #4 on: 23 April 2010, 20:16 »
Manual here:
Nice one... thanks.  Saved to my computer for future reference  :wink:
Offline p3asa
« Reply #5 on: 24 April 2010, 23:08 »
p3eps, I came across an actual PDF rather than a scanned copy of the manual here
http://ws.skoda-auto.com/download/4all/Documentation/en/Olders/Octavia/navigation/A5_Octavia_Columbus_NavigationSystem.pdf
Its for the Skoda version but they are exactly the same.
Offline p3eps
« Reply #6 on: 25 April 2010, 20:45 »
Thanks for that... although I still can't get her to speak!  I can catch the 'Navigation Volume' if I turn it up when she should be speaking - and its set to full.  I also have the 'Voice Guidance' set to on in the Setup -> Navigation menu.
It worked for a couple of days... but its maybe since I upgraded the firmware to 2720 that my lady had gone away  :cry:
Offline mr gee
« Reply #7 on: 28 April 2010, 11:33 »
In the tone setup, in Volume, there is a section on navigation and the amount of attenuation you want to set when the nav voice speaks up.
Offline ErikGTI
« Reply #8 on: 28 April 2010, 13:24 »
Right...that is the correct answer.. :wink:
I had the same problem yesterday and searched quite a bit...this solved it...a bit user-unfriendly here since you are tempted to think it is for your audiosystem...
It is the "first volume line"......mind you I still do not know what the implication of the "second volume line" is....a kind of minimum attenuation... :undecided:
« Last Edit: 28 April 2010, 13:27 by Erik van Voorst »
I'LL BEAT YOU TO THE BBC STUDIO........
Offline p3eps
« Reply #9 on: 28 April 2010, 19:44 »
Once again - thanks for the suggestions - but it didn't fix it!
I set both volumes up pretty high... but no success.
I'm thinking I should maybe try changing the firmware version.
Its not a huge problem, as I'm not going anywhere that needs Nav for a while... its just a little bit annoying when something doesn't work right  :angry:
