Author Topic: vr6 advice needed  (Read 2081 times)
Offline mar_k
vr6 advice needed
« on: 23 April 2010, 12:32 »
hi guys, ive got to change the rocker cover gasket on a P - reg vr6,
is it a big job or quite straight forward?
any advice or hinters would be greatfully apprecited
Offline snifferdog
Re: vr6 advice needed
« Reply #1 on: 23 April 2010, 12:37 »
Easy peasy mate! Its pretty self explanatory when you get under the bonnet. Just undo all of the bolts around the rocker cover and move or unplug anything else thats in the way. I believe you have to replace the bolts to the correct torque settings though.
Offline snifferdog
« Reply #2 on: 23 April 2010, 12:37 »
Whoops i see its a vr6, i was going on 8v gti, cant help you mate! :grin:
Offline mar_k
« Reply #3 on: 23 April 2010, 12:44 »
no worries fella,
lol
« Reply #4 on: 23 April 2010, 12:47 »
Inlet manifold gasket will be needed as you need to remove it.
Offline mar_k
« Reply #5 on: 23 April 2010, 13:05 »
cheers wayne, other than that is it a big job?
how long do you think it takes?
« Reply #6 on: 23 April 2010, 13:49 »
I would allow a couple of hours to be honest.
Offline mar_k
« Reply #7 on: 23 April 2010, 14:50 »
ok thanks for the advice
Offline AudiA8Quattro
« Reply #8 on: 23 April 2010, 23:56 »
I think its similar to doing the 16v, been along time since i've done one.
Allow a couple of hours. Once the upper inlet manifold is off, its pretty straight foward.
Offline mar_k
« Reply #9 on: 25 April 2010, 10:41 »
anyone know what torque settings the rocker bolts should be set too or is it ok to titghten roughly by hand
