Author Topic: Right lads next problem !!!!! gttdi 110  (Read 1091 times)
Offline mk4 nutter
« on: 23 April 2010, 11:56 »
New engine fitted all ok ! starts first time off the button BUT when warm it turns over quite a bit before it fires
any thoughts ????
Offline mk4 nutter
Re: Right lads next problem !!!!! gttdi 110
« Reply #1 on: 24 April 2010, 09:37 »
Bumpety bump anyone ??????? :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 24 April 2010, 10:05 »
very very common problem - you can try changing the coolant temperature sensor, sometimes that's all that is needed... but generally it seems to be a pump timing issue which can be worked around by convincing the car's ECU that it's an automatic, which alters the pump timing on startup.
