Author Topic: How can i tell if my car is set to longlife service or standard time Distance ?  (Read 1656 times)
Offline Fanters
I was told it was set to longlife but i've done 1200 miles and it reckons i'm going to need a service in 8100 miles.
Also should i be able to buy the £250 30,000 mile service pack if i'm set to longlife service ?
Golf GTI 5DR DSG White, ACC, Xenons, 18" Monza's, RCD 510, DAB, Bluetooth phone Prep, Lux Pack
Offline Das Auto
Its a letter after the chassis number in the service book I cant remember which though have a read of the service book and it will tell u
Offline FamilyDub
That's only 9.5k miles between services (it's calibrated in km), which is firmly T&D territory.   :nerd:
Unless you do loads of miles each day on motorways, stick with T&D; it's far better for the engine and it can work out cheaper
« Last Edit: 23 April 2010, 12:27 by FamilyDub »
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
