Author Topic: 2.0 GTI wont start  (Read 5817 times)
Offline Dariusdpd
2.0 GTI wont start
« on: 21 April 2010, 13:54 »
2.0 GTI car wont start,no spark from coil.coil working,tested...any ideas?
« Last Edit: 22 April 2010, 21:36 by Dariusdpd »
Offline javalin
Re: 2.0 GTI wont start
« Reply #1 on: 23 April 2010, 18:51 »
ECU relay, crank sensor or wiring fault somewhere in between
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Dariusdpd
« Reply #2 on: 24 April 2010, 03:05 »
James
relay is ok (number 30),checked in other vw golf,but i cant check crank sensor,need to buy a new one...i hope there will be the problem... :undecided:
Offline javalin
« Reply #3 on: 24 April 2010, 10:23 »
goto GSF - VW want £180 for them.  GSF want £45 or so.  Works fine - fitted one to my AGG not long ago.
James
Offline Khare
  • The bear that khares
« Reply #4 on: 24 April 2010, 14:49 »
it would be cheaper to get the car on vagcom. That should pin point the problem.
Offline Dariusdpd
« Reply #5 on: 28 April 2010, 14:43 »
VAGCOM (old one) cant see any problems...anyway,waiting for new crank sensor,will be fitted today...
YEPPP,crank sensor was the problem,now runs like new ! :D
« Last Edit: 29 April 2010, 11:47 by Dariusdpd »
Offline javalin
« Reply #6 on: 30 April 2010, 13:44 »
good news!
