Author Topic: should i do it?  (Read 3643 times)
Offline Nino
should i do it?
« on: 21 April 2010, 07:48 »
Hey peps,
OK so for the last couple of months ive noticed my exsault system has been blowing, so i took it to kik fit and they tell me my whole CAT & backbox are buggered plus there convinced my engine is only running on 3 Clinders  :undecided:
now i can agree that my exsualt system is bugged but with my car still able to reach speeds over 100mph i found it hard to beleave that it was only running on 3 cil.
i took it to a company call "pro speeds" for a 2nd opinion, tell have told me that my car is defo mis firing, he thinks it could be down to the coil pack? but he has looked and told me that my Flexi pipe, Cat and backbox all need replacing.
Now he told me that he will put on a New CAT, Felxi pipe & twin pipe backbox full stainless steel with a life time warrenty for £487.
I have it booxed in for next monday and im pritty excited to get it fixed, he has advised me that i get my engine tuned to stop the misfire, im thinking that the engine is finding it hard to push out the pressure because of the condision the backbox and exsualt sysem is in, the car only sound slike it isnt running correct when it is idel but if i give it alittle rev the shuddering stops (which i was told is a misfire)
What do you guys think?
its a 1.8 gv GL btw.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Re: should i do it?
« Reply #1 on: 21 April 2010, 08:53 »
I would seek a 3rd opinion, £487 is a lot of money to fork out.
Offline big_cal
Re: should i do it?
« Reply #2 on: 21 April 2010, 09:26 »
Id try and stay away from sh*t fit!!
i had a similar problem they told me my mid box and back box needed replacing and it was going to cost me around £100 a piece fitted, it was a while back but cant remember the exact figure!!
So i went to a auto spares and picked them both up for around £70 and had a go at them with a mate.
It turns out the problem is still there, cheers sh*t fit!!
so i took it to a friend of a friends garage and he diagnosed it as the flexi-pipe and fixed the problem for £100!
Offline VR6-Joe
Re: should i do it?
« Reply #3 on: 21 April 2010, 09:50 »
£487?!
HOWWWWWW MUUUUUUUUUCH?????????????
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline justalex81
Re: should i do it?
« Reply #4 on: 21 April 2010, 10:15 »
firstly if your engine was only running on 3 cylinders you'd definately know about it (unless it's an 8v cause they're all slow  :grin: :grin: :grin:
if it's misfiring then it's probably to do with the fact that your cat and exhaust are shagged!
a cat for a mk3 gti isn't that dear and you can get a complete stainless system for £350
plus i'd never buy from kwik fit. they could sell you cheap stainless parts with thin walls (like magnex ones) that make too much noise
Offline jonnypolish
  • t2871r needed :)
Re: should i do it?
« Reply #5 on: 21 April 2010, 10:28 »
+1 :D
Am i reading incorrectly but isn't he saying that this "Pro sports" place is charging the £487?
If you were doing all this work i would invest in a COMPLETE new pipe!
Solves the problem of other bits going for years to come :)
 MK2 VR y0!
Offline essexboy123
  • facebook: jon dervish
Re: should i do it?
« Reply #6 on: 21 April 2010, 18:23 »
thats why you don't go to quick fit!!!
"you cant fit sh!tter than a quick fit fitter"  :smiley:
Offline snifferdog
Re: should i do it?
« Reply #7 on: 21 April 2010, 19:28 »
Definately agree with that! You can usually get the same job done for less cash and to a higher quality if you shop around!
Offline christomk3gti
Re: should i do it?
« Reply #8 on: 21 April 2010, 19:46 »
It'd be noticeable if you were only firing on 3 cylinders,
1. You'd hear it spluttering.
2. You'd find your using more petrol.
3. Power will be down
and regarding '3' wether its an 8v or not, its irrelivant.
And i'd probably beat you's in your 16v's anyway  :grin:  :grin:
 :rolleyes:
Black 8v GTI............. Whats a Waffle Valve?
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: should i do it?
« Reply #9 on: 21 April 2010, 19:49 »
 :rolleyes:
And 4. it would sound kinda like a terminally ill scooby.
