Author Topic: rear wiper removal question  (Read 2200 times)
Offline jimmy1888
« on: 20 April 2010, 19:45 »
Hi folks,
I have just ordered the glass gromet for covering up the hole when you remove the rear wiper what i want to know is when you are removing the rear wiper, do you just remove the spindel for the wiper arm and seal off the water pipe, fit glass gromet, job done? or is it more complicated?
Any info would be great
cheers
jim :smiley:
Offline wakeboarder15
Re: rear wiper removal question
« Reply #1 on: 20 April 2010, 21:46 »
hi
i did this very recently!
basically you are going to have to take the whole rear wiper motor out (very easy - held on by 3 bolts)
 and yes plug the water pipe thingy!
to get to the rear wiper motor take the boot door card off (2 screws in grab handles and then pull - firmly to disconnect tabs)
hope this helps
cheers
elliot
Offline Dave_IOW
« Reply #2 on: 20 April 2010, 21:52 »
what size is grommet? Where you get it from?
Edit: Answer to my own question is 25mm.
« Last Edit: 20 April 2010, 22:11 by Dave_IOW »
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline jimmy1888
« Reply #3 on: 21 April 2010, 08:14 »
 :grin:
i got it from venom motorsport. im sure its £23
hi
hope this helps
cheers
elliot
very helpfull bud cheers  :smiley:
Offline tg1
« Reply #4 on: 21 April 2010, 08:15 »
what did you use to block the hose off?
« Reply #5 on: 21 April 2010, 13:55 »
i squired a load of silocone in the end
then a load of duck tape round that
then folded it in half tightly
and then more duck tape around the fold to make sure it stayed tight
dont think it is going to be leaking any time soon!
cheers
elliot
Offline topher
  • Administrator
  • fully functioning
Offline gjroe78
« Reply #7 on: 21 April 2010, 17:03 »
ooops  :embarassed: :tongue:
Offline richw911
Offline jimmy1888
« Reply #9 on: 21 April 2010, 19:42 »
yep thats the one :grin:
