Author Topic: Grrrrrr Start!!!!!  (Read 1794 times)
Offline benjam_in
Grrrrrr Start!!!!!
« on: 25 November 2004, 12:53 »
Bloody car wont start! turns over nicely but wont fire! did once for afew seconds then died! any ideas boys?  ::)
Golf Mk2 Gti 1988
Blue MK2
Re: Grrrrrr Start!!!!!
« Reply #1 on: 25 November 2004, 13:15 »
fuel pump, relay, lift pump thing in the fuel tank?
does the pump whine for about 2-3 seconds when the ignition is on?
no fuel  :D
VeeDubGTI16v
« Reply #2 on: 25 November 2004, 14:05 »
are you getting a spark, check that first ;)
Offline benjam_in
« Reply #3 on: 25 November 2004, 14:50 »
the only way of doing that i know hurts a lot!
Golf Mk2 Gti 1988
VeeDubGTI16v
« Reply #4 on: 25 November 2004, 14:51 »
yeah put the ht leads bout a cm from your arse to test >:D
Offline Agreeable Slick
  • Unit
« Reply #5 on: 25 November 2004, 15:42 »
umm just pull the HT lead off, unscrew the plug, and put the HT lead on it, then get someone to turn the engine over whilst you look for a spark.
Not hard, or painfull.
« Reply #6 on: 25 November 2004, 17:07 »
Change dizzy & rotor arm, solved starting issues on my gf's AX, would turn over for ages before it would start, and liked to cut out randomly.
Offline ...joe
« Reply #7 on: 25 November 2004, 21:27 »
unscrew a plug and attatch it to the lead, then stick it through the engine lifting eyelet to check for spark, check rotor arm, check for fuel,
do what everyone else said and what i re-iterated!!! :P
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
