Author Topic: Roof aerial blanking grommet  (Read 2381 times)
Offline Mr.Tom
« on: 19 April 2010, 07:07 »
Does anyone know where I can get a blanking grommet to replace the ROOF aerial? Wing ones are all over the place, but nobody seems to do one for the roof. I know there must be one somewhere as I have seen it done, but the chap was going a bit quick to ask :D.
I am not sure of the size or shape of the hole yet, but someone suggested possibly using a grommet from an electrical box.
Any ideas?
Re: Roof aerial blanking grommet
« Reply #1 on: 19 April 2010, 12:46 »
Halfords sell assorted packets one of those should be the right size.
Offline snifferdog
« Reply #2 on: 20 April 2010, 21:07 »
I got an assorted pack from halfords for about £1.49, i think it was the 22mm one!!
Offline gazpowells
« Reply #3 on: 20 April 2010, 21:23 »
i want one aswell so will try halfords tomorrow  :smiley:
Offline snifferdog
« Reply #4 on: 21 April 2010, 21:08 »
Whoops i misread, i thought you were talkin about the rear wiper for some reason?! I bought an aerial blanking grommet from ebay for about £2.50 before!!
Offline Mr.Tom
« Reply #5 on: 28 April 2010, 18:16 »
I went a different route in the end.
Took off the aerial to find a square hole :/ Figured I wouldn't find a grommet anywhere easily to fit it (it was about 12mm by eye I would say)
I stuck a piece of firm plastic to the underside (leaving a small pocket which allowed filler to spread out around the edge of the hole)
Then filled it with epoxy filler, making sure to squidge it into the gap under the hole for a better grip.
Sanded it down and sprayed a very small area around the hole where the aerial base had chipped the paint a little (also filled)
Going to let the paint dry overnight then sand it down and give it another coat, then blend the edges.
It's such a small area, and not in a particularly noticeable place, so I am happy to have the small square not being a perfect match, but it is damn close :).
In my eyes, much nicer than a big black piece of plastic sticking up end being more noticeable :D
