Author Topic: No Boost....me thinks! Please comment and help if you can  (Read 1123 times)
Offline Big Tone
Please see below a log of 3rd gear from 2000revs up to 5000revs
I read this as the car is asking for the same amount of boost all the way through and only asks for more boost at  295 to 303 seconds, this is my first crack at this so please bear with me and help me if you can.
What could cause this?
Group A:   '115         Group B:   '004            Group C:   '002
   Engine Speed   Spec. Boost   Actual Boost      Idle speed   ECM Voltage   Coolant Temp   Intake Temp      Idle speed   Engine load   Inj. period   Air mass in
TIME   700-6800 RPM   990-1800 mbar   <=1800 mbar   TIME   700-820 rpm   12-15V   80-110 C   -48-110C   TIME   700-820 rpm   15-25%   2.0 - 4.0 ms   2.0-4.5 g/s
STAMP    /min    mbar    mbar   STAMP    /min    V   Â°C   Â°C   STAMP    /min   %    ms    g/s
246.07   1880   1010   1040   246.47   1800   14.28   67   17   246.97   1760   13.5   0   4.61
247.37   1680   1010   1040   247.78   1560   14.28   67   17   248.17   1480   12   0   3.42
248.58   1400   1010   1040   248.99   1360   14.21   66   18   249.38   1280   11.3   0   2.97
249.78   1240   1010   1030   250.2   1200   14.28   66   18   250.7   1160   12.8   2.04   2.94
251.1   1200   1010   1030   251.5   1160   14.21   66   18   251.9   1160   24.8   3.06   5.81
252.31   1160   1010   1030   252.81   1160   14.28   66   18   253.3   1120   23.3   2.38   5.22
253.72   1120   1010   1030   254.12   1120   14.28   66   18   254.62   1120   18.8   2.04   4.17
255.13   1120   1010   1030   255.53   1120   14.21   66   18   255.93   1120   27.8   2.72   6.03
256.33   1120   1010   1030   256.73   1120   14.21   66   18   257.24   1120   30.1   3.06   6.86
257.64   1160   1010   1030   258.04   1160   14.21   66   18   258.44   1200   49.6   5.78   12.03
258.84   1200   1010   1040   259.35   1240   14.28   66   17   259.75   1280   50.4   5.44   12.31
260.15   1320   1010   1050   260.55   1360   14.28   66   17   260.95   1360   54.9   6.12   14.89
261.35   1400   1010   1060   261.77   1440   14.28   66   16   262.26   1480   53.4   6.12   15.5
262.76   1560   1010   1060   263.17   1600   14.28   66   16   263.57   1640   60.2   6.46   19.33
264.07   1680   1010   1100   264.47   1760   14.28   66   15   264.87   1760   49.6   5.1   15.53
265.29   1800   1010   1070   265.69   1800   14.07   66   15   266.09   1840   34.6   3.4   11.86
266.49   1840   1010   1050   266.89   1840   14.28   66   15   267.29   1840   33.8   3.4   11.25
267.69   1880   1010   1040   268.1   1880   14.28   66   15   268.5   1880   33.8   3.74   12.17
268.9   1880   1010   1040   269.4   1920   14.28   66   16   269.8   1920   36.1   4.08   13.08
270.21   1960   1010   1050   270.71   1960   14.21   66   16   271.11   1960   38.3   4.08   14.22
271.51   2000   1010   1050   271.92   2000   14.28   66   16   272.32   2000   39.1   4.42   15.17
272.72   2040   1010   1060   273.12   2080   14.28   66   15   273.52   2080   42.9   4.76   16.61
273.92   2120   1010   1070   274.32   2120   14.28   66   15   274.74   2160   47.4   5.1   19.31
275.14   2160   1010   1080   275.54   2200   14.35   67   15   275.94   2200   46.6   5.1   19.06
276.34   2240   1010   1090   276.85   2280   14.35   67   15   277.35   2320   45.9   5.1   19.58
277.75   2320   1010   1090   278.15   2320   14.28   67   15   278.55   2360   44.4   5.1   19.5
278.96   2400   1010   1090   279.36   2400   14.28   67   15   279.76   2440   44.4   4.76   19.72
280.26   2440   1010   1090   280.68   2440   14.28   67   15   281.08   2480   39.8   4.42   18.25
281.57   2480   1010   1080   281.97   2480   14.28   67   15   282.48   2520   38.3   4.42   16.81
282.98   2520   1010   1070   283.38   2520   14.35   67   15   283.78   2520   36.1   4.08   16.72
284.2   2560   1010   1070   284.59   2560   14.28   67   15   284.99   2560   37.6   4.42   17.78
285.39   2600   1010   1070   285.79   2600   14.28   67   15   286.19   2640   39.1   4.42   18.42
286.59   2640   1010   1080   287.01   2680   14.28   67   15   287.51   2680   32.3   3.74   16.03
287.91   2680   1010   1070   288.42   2720   14.28   67   15   288.82   2720   31.6   3.74   15.86
289.22   2720   1010   1060   289.62   2760   14.28   67   15   290.02   2760   33.8   3.74   17.08
290.53   2800   1010   1070   291.03   2800   14.35   68   15   291.43   2840   36.8   4.08   19
291.94   2840   1010   1070   292.43   2840   14.35   68   15   292.83   2840   22.6   2.38   12.39
293.23   2840   1010   1040   293.65   2840   14.28   68   15   294.15   2880   33.8   3.74   18.58
294.55   2880   1010   1070   294.95   2880   14.28   68   15   295.34   2960   58.6   8.5   41.58
295.76   3000   1160   1370   296.26   3120   14.21   68   15   296.66   3240   133.8   15.64   86.03
297.17   3360   1470   1460   297.57   3480   14.14   68   16   297.97   3600   127.1   13.6   88.78
298.37   3720   1470   1470   298.77   3840   14.14   68   17   299.28   3960   125.6   13.26   95.14
299.68   4080   1470   1470   300.08   4200   14.21   68   17   300.5   4320   128.6   13.6   107.11
300.99   4440   1470   1470   301.39   4560   14.28   68   18   301.79   4680   132.3   13.94   118.89
302.21   4760   1440   1440   302.61   4880   14.21   68   19   303.1   4960   132.3   13.94   128.25
303.6   5080   1410   1430   304.02   5160   14.14   68   20   304.42   5280   132.3   14.28   134.11
304.91   5360   1010   1400   305.31   4880   14.28   68   20   305.71   4160   12   0   4.72
306.11   3480   101 0   1080   306.62   3240   14.21   68   18   307.02   3280   12   0   6.22
307.42   3280   1010   1050   307.82   3200   14.28   68   18   308.22   3200   12   0   7.47
308.73   3160   1010   1050   309.13   3120   14.28   68   18   309.53   3080   12   0   7.22
309.93   3080   1010   1050   310.33   3040   14.28   68   18   310.85   3000   12.8   0   7.69
311.34   2960   1010   1050   311.74   2920   14.21   68   18   312.14   2920   13.5   0   7.75
312.54   2880   1010   1050   312.96   2840   14.35   68   18   313.36   2800   13.5   0   7.33
313.76   2800   1010   1040   314.16   2760   14.28   67   18   314.56   2720   13.5   0   7.47
314.96   2680   1010   1040   315.37   2680   14.28   67   18   315.87   2640   12.8   2.04   6.58
316.27   2600   1010   1040   316.67   2600   14.28   67   18   317.07   2560   12.8   1.7   6.31
317.49   2520   1010   1030   317.89   2520   14.21   67   18   318.29   2480   15.8   1.7   7.75
318.69   2480   1010   1030   319.08   2480   14.28   67   18   319.48   2440   19.5   2.38   9.72
319.88   2440   1010   1030   320.3   2400   14.14   67   18   320.7   2400   23.3   2.72   11.17
321.1   2360   1010   1040   321.5   2360   14.28   67   17   321.9   2360   27.1   3.06   12.5
322.3   2320   1010   1040   322.7   2320   14.28   67   17   323.12   2320   30.1   3.4   13.42
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline topher
  • Administrator
  • fully functioning
Re: No Boost....me thinks! Please comment and help if you can
« Reply #1 on: 16 April 2010, 16:56 »
Something broken there dude. There is no requested boost at all until 3000 rpm for some reason, the 1010mb is just atmospheric pressure. Any fault codes at all? Your MAF readings appear to be screwy before 3000rpm too. Was your foot flat to the floor on the pedal from 2000 to 5000?
It'd be handy if you could get more logs but individual values, so that you get a higher sample rate. Logging 3 MVB's at once is a bit slow on mk4 ecus. Fire the csv files over to me topher@golfgti.co.uk and i can chart them to make a bit more sense for you.
Offline Big Tone
« Reply #2 on: 16 April 2010, 17:11 »
Nice one, Ill do it again this evening.
Much appreciated
