Author Topic: Bonnet release.  (Read 8488 times)
Offline Coolhandluke
Bonnet release.
« on: 16 April 2010, 14:36 »
The bonnet release lever in the footwell isn't releasing the bonnet catch.
Any suggestions as to what my options are to get it working again?
Offline luvmygti
Re: Bonnet release.
« Reply #1 on: 16 April 2010, 14:53 »
Hi mate,
Is the handle its self snaped or does it feel like the cable is is not connected/snaped?
MKV GTI/ 3 Door/ 18" Monza II/ Full leather/ heated seats/ Manual/ Arm rest/ 6 Disc changer/ Cruse control/ Highline MFD/ Xenons/ Dog's Nuts!
Re: Bonnet release.
« Reply #2 on: 16 April 2010, 18:54 »
The handle is working fine but the bonnet catch just dosn't seem to want to release when i pull on the handle,i dont think the cable is broken either.
There dosn't seem to be any way of getting to the bonnet release catch from the outside,bit of a sticky one so to speak.
Its a June 2006 car and i  bought it from a VW Dealer in February this year so it came with 12 months warranty.
Would this problem be covered by the warranty?
« Last Edit: 16 April 2010, 20:51 by Coolhandluke »
Offline luvmygti
Re: Bonnet release.
« Reply #3 on: 19 April 2010, 08:57 »
Its a right faf of a job!!!
You need to remove the engine undertray and put your hand up the back of the grille to the bonnet catch and do it that way.
But the good news is i cant see any reason it wouldn't be covered by a vw extended warranty  :smiley:
Offline AlanD
  • MK5 2.0T 16v
Re: Bonnet release.
« Reply #4 on: 19 April 2010, 09:12 »
It'll be covered by VW, take it back to them and get them to fix it.
You pay a premium buying from a dealer + the 12 month warrenty so make the most it whilst it lasts.
Re: Bonnet release.
« Reply #5 on: 23 April 2010, 19:49 »
Local VW dealer (not the one i bought it from) is looking £49 just to look at it.
If what caused the problem is covered by warranty then that charge will be waivered but they need to investigate first.
They say it may not be covered under the warrenty as it involves a cable that may require adjustment.
Having had a closer look myself it looks as if the cable end has become detatched from the catch itself.
Does the VW badge in the grille just pull out? as it looks as if you might get access to it from there.
Offline IBD4vid
Re: Bonnet release.
« Reply #6 on: 24 April 2010, 03:00 »
Mine has done the same  :cry: remove the vw badge and there is 3 screws undo them and lift bonnet :)
visit my car site www.mycarsevolution.co.uk
The GTI Rep Coming Soon
Re: Bonnet release.
« Reply #7 on: 24 April 2010, 13:18 »
I take you just pull on the VW badge to remove it?
There is a bit of give in it,just dont want to go breaking anything at the back of it.
Do the 3 screws secure the catch?
Offline AlanD
  • MK5 2.0T 16v
Re: Bonnet release.
« Reply #8 on: 24 April 2010, 13:47 »
Noooo, don't just pull it you will break it. Its either a quarter twist left or right with a bit of force and then pull it towards you. There might be a clip or something, I cant really remember to be honest lol.
Try a quick Google search.
Re: Bonnet release.
« Reply #9 on: 24 April 2010, 17:23 »
Yes you are right,a turn to the left is required to remove it.
Can't see the 3 screws that are mentioned,can only see a plastic type cover & 2 torx headed type screws which seem to hold it in place.
Where exactly are the screws you mention?
