Author Topic: Possible ECU Problem Part 2: Help Still Needed  (Read 1591 times)
Offline brendan
« on: 15 April 2010, 22:18 »
Following on from my other thread, I'm having another problem.
I now have found a pattern in the fault that keeps occuring. After I  drive my car for the 1st mile into my journey, my car suddenly goes into limp mode and runs on 3 cylinders. If I then leave it for a few minutes, usually around 10 minutes, it jumps back into life and is fine for the rest of the day. I'm really confused and all I can think of is that I have some sort of temperature sensor problem? I have had it on a code reader the first time it happened and all it said was 'Cylinder 3 Misfire'. I pressume I have the same fault although I can't check as I don't own a code reader. It's going on one on Saturday hopefully. I'm pretty sure it's not a coil pack problem as all 4 are only a month old.
I have also been told I could have any of the following faults:
ECU Problem/Breakdown
Temperature Sensor Faulty
Faulty Injector
If anyone could shed any light it would be a great help as this is really annoying now.
2009 Ford Focus ST2 - 288bhp, 390lb/ft
Offline GOLF_STU
  • THE_GIT
Re: Possible ECU Problem Part 2: Help Still Needed
« Reply #1 on: 15 April 2010, 22:24 »
try swapping the coil pack and injector and see if you can alter the cylinder missfire fault.
V TEC KICKED IN Y'ALL!!!
Offline brendan
« Reply #2 on: 15 April 2010, 22:28 »
I've tried the coil pack but haven't touched the injectors yet. The fault still stays the same. I wouldn't feel confident messing around with them though.
It doesn't explain why its a mile into my journey though, and then fine after a while.
Offline GOLF_STU
  • THE_GIT
« Reply #3 on: 15 April 2010, 22:32 »
is it just the engine management light your getting? have you stripped the tape back on the coil pack wiring? mine was playing up when i first got it the wire had perished and was earthing on the head.
Offline brendan
« Reply #4 on: 15 April 2010, 22:37 »
Funny you should say that, I thought it was the cables first so I have got a new wiring loom for the coil packs but have been told that this may not even solve the problem. I don't fancy paying to get it fitted and find it doesn't solve it. Surely a dodgy cable wouldn't break at the same time and place everyday.
Offline GOLF_STU
  • THE_GIT
« Reply #5 on: 15 April 2010, 22:39 »
yeah thinkin of it it would do it all the time.........where does your temp guage sit when warmed up?
Offline brendan
« Reply #6 on: 15 April 2010, 22:42 »
Thats the confusing part, it sits at 90 all day long. Not long had the water pump changed too.
Offline GOLF_STU
  • THE_GIT
« Reply #7 on: 15 April 2010, 22:55 »
silly question have you tried cleaning the throttle body?
Offline brendan
« Reply #8 on: 15 April 2010, 22:57 »
Yeah it was cleaned before I had my Remap about a month ago.
Offline brendan
« Reply #9 on: 16 April 2010, 08:25 »
Bump.
