Author Topic: wheres my water going?  (Read 2937 times)
Offline bully85
« on: 14 April 2010, 18:15 »
hi i have a 1.8 8v and iam losein alot of water over 2/3 days about 1.5l's cant see anyleaks. trying to sort out a overheatin problem in the past i changed the water pump headertank and cap thermo stat fan swich radiator temp sender wich fixed the overheatin problem runs in the middel now just the water loss drivein me mad any ideas?come on jonny show me the way!
Offline kraM
  • It's not the speed, it's the sudden stops...
Re: wheres my water going?
« Reply #1 on: 14 April 2010, 20:32 »
what colour 'steam' is coming from your exhaust?
HEAD GASKET
What's the underside of the Oil filler cap look like?
HEAD GASKET
Are your carpets wet?
HEATER MATRIX
Do you have a damp patch.  Under the car?
GENERAL LEAK
kraM  (who has enough time to colour code the  :smiley: of the fault...)
It's not the speed... it's the sudden stops...
Offline SoundillusioN
« Reply #2 on: 14 April 2010, 20:59 »
Damn you are bored  :laugh:
+1
ive just put my engine  back together and was also loosing water with no visable leaks... it tuned out it was coming from the valve behind the inlet manifold thats connected to your heater controls in the dash... might be worth a look too.
« Reply #3 on: 14 April 2010, 21:01 »
Get it pressure tested should find your leak.
Offline gibby
« Reply #4 on: 14 April 2010, 22:31 »
Have a look at the flange to the right of the block (as you look at it from the front) which connects to the metal water pipes (apologies for lack of a better description :rolleyes: ). Had this leak on a mk1 cab and it was a b1tch to find as the water evaporated when it hit the block, so didn't drip on the floor, so couldn't fine the leak. Pah !
......now officially dubless.
Offline raferackstraw
« Reply #5 on: 14 April 2010, 22:47 »
HEAD GASKET
HEAD GASKET
HEATER MATRIX
GENERAL LEAK
yea but not to pm about wether he wants a clip on or not  :rolleyes:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline kraM
« Reply #6 on: 16 April 2010, 12:30 »
I'm really sorry, I did, but it never got to you.   :cry:
I've PM'd you again.
kraM
