Author Topic: Possilbe ECU Problem. Can anyone help?  (Read 2757 times)
Offline brendan
« on: 14 April 2010, 10:52 »
I really need some urgent help on my MK4 GTi Turbo.
Yesterday my car started missfiring really badly and had no power at all so I had to pull over. I called the AA out and he diagnosed it with a scanner as Cylinder Number 3 missfire. I changed all the Coil Packs a month ago for genuine VW items and also the spark plugs. I pulled the coil pack out and put it back in, then started the engine and it started as normal. It then stayed like this all day with no problems, as I drove at least 80 miles yesterday. Great I thought, problem solved!
No, Maybe not. This morning whilst driving the car, the same thing happened again. So luckily I was driving past an auto electrics place near me and got them to have a look at it. Exactly the same problem again, so I pulled the coil pack out and put it pack in again. The car worked as normal.
He seems to think that there is a possible ECU fault, and that I need to get it on a proper VW scanner. I've also asked a few other places and they all seem to think the same. I'm worried this is going to cost me a fortune now as I don't like the sound of a new ECU.
The car will hopefully be going up to R-Tech later if I can get a lift, but in the mean time can anyone help me?
Thanks.
2009 Ford Focus ST2 - 288bhp, 390lb/ft
Offline T_J_G
Re: Possilbe ECU Problem. Can anyone help?
« Reply #1 on: 14 April 2010, 10:59 »
Dodgy wiring to the coilpack?
A VAGCOM scan will only show up the same as the AA fault codes.
Offline brendan
« Reply #2 on: 14 April 2010, 11:22 »
I'm not sure tbh, it could be. Its very intermitant. I'm really lost now.
Offline T_J_G
« Reply #3 on: 14 April 2010, 11:24 »
Have you tried another coil pack? It may be worth it, if it don't fix it you could rule it out and keep it as a spare in your car if any of the other ones go?!
Offline Rhyso
« Reply #4 on: 14 April 2010, 11:25 »
have you swapped the coil pack from one cylinder to another?
if the mis-fire occurs on the other cylinder then you know the coilpack is at fault, if it occurs on the same cylinder then its possibly a wiring fault
Offline brendan
« Reply #5 on: 14 April 2010, 11:26 »
Yup I put the spare one in yesterday and it cured it, thought that was the end of it. Then it happened again this morning so I put the new one back in and its ok again.
Offline Rhyso
« Reply #6 on: 14 April 2010, 11:27 »
sounds like a possible wiring fault then  :undecided:
Offline brendan
« Reply #7 on: 14 April 2010, 11:27 »
I've tried two coil packs in the same cylinder and it's happened twice now. Where do I start with the wiring?
Offline T_J_G
« Reply #8 on: 14 April 2010, 11:28 »
Ah so it's got to be a wiring fault. That rules out the coil pack.
The witing runs from the plug across and down the back behind the TIP I think.
Mr_Orange changed his coilpack harness on here and got a heat shield from the Audi TT to stop the detiration again. Although I can't find any links. :(
Offline Rhyso
« Reply #9 on: 14 April 2010, 11:31 »
