Author Topic: "lag" when changing gear!!! 1.8T  (Read 5767 times)
Offline Big Tone
« on: 12 April 2010, 18:44 »
Ive got this weird boost type problem. if i change gear at high ish revs say 5000 then put my foot down hard in the next gear, nothing really happens for a while about 3-4 seconds an then the turbo comes in with force! any ideas?
No fault codes. Charge to pancake to intercooler to throttle body air route, all hoses new, and tight as you like.
I am running standard, want to sort this out before I map it, sometimes I feel it lower down in the rev range too, but at high revs it does it everytime.
Has anyone else experienced this?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline richw911
Re: "lag" when changing gear!!! 1.8T
« Reply #1 on: 12 April 2010, 18:49 »
You will get some lag obviously.
Faulty N75  :undecided:
« Last Edit: 12 April 2010, 18:59 by richw911 »
Offline Big Tone
« Reply #2 on: 12 April 2010, 18:53 »
I know its not going to be instant boost but this is arount 3-5 seconds of lag! to the extent of I lose a fair bit of speed only to accellerate again when the boost comes in.
Was thinking a control issue, N75 or N249 (not bypassed yet, this weekends' job) but by no means am 100%.
Its as if the DV takes time to operate (Sometimes), if that makes sense?
Offline tg1
« Reply #3 on: 12 April 2010, 23:06 »
sticky actuator perhaps?
Offline Big Tone
« Reply #4 on: 13 April 2010, 12:37 »
This is something I have not come across, when you say "actuator" what exactly are you referring to? N249?
Offline Rhyso
« Reply #5 on: 13 April 2010, 12:38 »
Actuator on the turbo itself
Offline Big Tone
« Reply #7 on: 13 April 2010, 17:29 »
Is there any way I can service/overhaul this?
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #8 on: 13 April 2010, 17:45 »
A good diagnostics session should help you pin point the issue.
Nick
 01455 617233
Offline Big Tone
« Reply #9 on: 13 April 2010, 18:12 »
Nick
I have Vag Com, but am a novice with the software, dont suppose you could tell me what I need to do?
Tony
