Author Topic: 8 valve and 16 valve gearboxes, are they compatible  (Read 2096 times)
Offline beechymonza
  • mad beech
Hiya lads, im a mk2 owner, But my mate who is not on here has gota  mk3 gti 8valve, His gearbox has broken,
So i been down local scrappage scheme scrap yard an they got a mk3 gti 16valve in there, An the geezer wants 200 quid 4 the lot, Engine Gear box an all ancillarys,
i dont know much about the gearboxes but will this gearbox fit on his 8 valve,
No guts No glory,
Offline Adam
Re: 8 valve and 16 valve gearboxes, are they compatible
« Reply #1 on: 12 April 2010, 13:15 »
Yep it will fit but you need to change the pedal box due to the 16v clutch being hydraulically operated.
Down Hill From Here.
Offline VR6-Joe
« Reply #2 on: 12 April 2010, 13:18 »
You sure it will fit??
I thought 16v was cable change and 8v was rod??
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Cable
« Reply #3 on: 12 April 2010, 13:22 »
yh not really worth changing, + you will have to get a master and slave cylinder for the clutch
Offline Adam
« Reply #4 on: 12 April 2010, 13:24 »
Forgot about that one as well, yea cable change.
Is it worth it? You might as well to drop the 16v engine in there as well.
Offline beechymonza
  • mad beech
« Reply #5 on: 12 April 2010, 13:42 »
Yeah i was gunna stick some of the engine bits in my mk2 16valve though, An tell him the gearbox cost 200 quid  :grin: :grin:
No guts No glory,
« Reply #6 on: 12 April 2010, 14:11 »
also have to fit 16v gearstick & cables, and flywheel & clutch. The hydro clutch you can work around by fitting SEAT ABF hydro->cable conversion kit.
