Author Topic: Key codes  (Read 1096 times)
Offline Cable
Key codes
« on: 12 April 2010, 07:24 »
Just wondering what will happen when i put the vr6 ecu in, will i need to code the keys? if so can vagcom do it?
Re: Key codes
« Reply #1 on: 12 April 2010, 08:58 »
depends if ecu is immobilised or not. pre-95 arnt, post 95 are. also, does your car have an immob, if not and ecu has one, nbeed to add the wiring and transponder box + reader coil from around the ign lock.
if you car has an immob, you can rematch the new ecu to your existing key + box with vag-com.  Otherwise you need to get a matched transponder box + key, then you can match. if you just have a transponder box, only VW can code you a fresh key.
if you can get a matched ecu, key and box then no need to mess about, just plug n play
Offline Cable
Re: Key codes
« Reply #2 on: 12 April 2010, 13:07 »
yh forgot to mention both are obd2, 16v to vr6, my car has the transpinder box, where abouts in vagcom do i go?
Thanks
Re: Key codes
« Reply #3 on: 12 April 2010, 14:13 »
Offline Cable
Re: Key codes
« Reply #4 on: 13 April 2010, 01:17 »
thanks  :smiley:
