Author Topic: Bulkhead hole for ICE installation  (Read 4145 times)
Offline rich1
« on: 04 August 2003, 14:34 »
hi, just wondering if anyone can suggest a hole which i can run the positive lead for my kenwood amp through in the bulkhead.
ive had a look but its all carpet, insulation, covers, plastic etc. so thought i may as well ask someone with prior knowledge rather than fannying around any longer!!
thanks
rich
p.s the cars a TDI 90 if it makes any difference and is 51 reg
Offline evergood
Re:Bulkhead hole for ICE installation
« Reply #1 on: 07 August 2003, 22:36 »
There is a hole through the bulk head, but you will have to remove the glove box first, which involves re moving the centre console in order to not damage the plastic join to the glove box. The hole is quite high up, it ends up going through just below the windscreen. I then ran the wire through the bracket for the bonet strut, then down to the battery. Very fiddly, took me 6 hours.
Good luck.
