Author Topic: Vag com problem  (Read 916 times)
Offline christomk3gti
Vag com problem
« on: 11 April 2010, 16:23 »
Hi guys, I've searched and not really found the answer...
I wanna connect the laptop to the car via the OBD 11 lead and vagcom program i have installed. 409.1
I managed to get it to work the first time and it seemed to find no faults.... BUT I cant get it to work again. the vagcom program just seems to crash and not respond then closes down. I went into options and it seems to find a connection via com1 but when i click autoscan it crashes now  :sad:
What the hell am i doing wrong??
I'm running Windows Vista, and my laptop is a fujitsu-siemens. (but that should be a problem?)
Black 8v GTI............. Whats a Waffle Valve?
Re: Vag com problem
« Reply #1 on: 11 April 2010, 16:31 »
I wonder wether its because i have a firewall running?? should i disable then try the scan again??
I read something about changing the com port settings??? but dont know how to do it. or if i need to do it.
hmmm confused.
