Author Topic: Humor me please  (Read 2655 times)
Offline bmw156
Humor me please
« on: 10 April 2010, 19:20 »
Hey guys, just homour me please and read on lol
my exhaust is always jumping of its hanger, it is after market and its a pain in the arse lol.
also, my engine seems to move alot, under accelaration, and i can push it about in the engine bay and the front mount looks like its doing nout.
could their be a fault engine mount, which is causing excessive movement, which would take the exhaust of its hanger.
if so, are engine mounts common faults. and i can see the rear one being a PITA to fit lol
Offline Reasty
  • Alpine white valver.
Re: Humor me please
« Reply #1 on: 10 April 2010, 20:16 »
If you can move the engine with your hand I defiantly say there's and engne mount gone if not more than one,I'd have this checked out asap,also if the engine was moving enough then it could possibly push/pull the exhaust off the hanger yes.
Offline Paul86S2
Re: Humor me please
« Reply #2 on: 10 April 2010, 20:28 »
Aftermarket exhausts tend to not have the ends on the hangers that stop the hangers coming off.
I hold mine on with a bit of wire coat hanger.
I also found a solid front engine mount helped a lot. A new OEM standard one should be ok for normal use.
Paul
Offline bmw156
Re: Humor me please
« Reply #3 on: 10 April 2010, 20:36 »
yeh, the front mount moves nicely when i move the engine. almost like its under no pressure lol.
my aftermarket exhaust has no end on the hangers like you say. i was thinking of welding on a washer on each one.
i might remove the front one, look at its condition. and then buy a new one from there.
cheers guys
Offline Reasty
Re: Humor me please
« Reply #4 on: 10 April 2010, 20:40 »
My bungees used to come off all the time but since I put poly ones on there the exhaust dosnt move and has stay on all three hangers nicely so it's worth putting them on,they are a right b!tch to put on but once they are your laughing  :smiley:
Offline bmw156
Re: Humor me please
« Reply #5 on: 10 April 2010, 20:47 »
i was thinking about them, where did you get them from, or were they just generic exhaust hangers poly style
and 3 hangers..... my back box has two, and the next box forward has two
Re: Humor me please
« Reply #6 on: 10 April 2010, 20:47 »
Sounds like you need a new front engine mount.
Offline jpgti
Re: Humor me please
« Reply #7 on: 10 April 2010, 21:29 »
Fix the engine mount ASAP man or your car will die lol
Offline Reasty
Re: Humor me please
« Reply #8 on: 10 April 2010, 21:39 »
Sorry i was using my mk2 as an example and that has 3 hangers,i got them from venom motorsport.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Humor me please
« Reply #9 on: 11 April 2010, 17:47 »
Engine mounts aren't to bad to change really, all you need is a socket set, a trolley jack and maybe a couple of spanners (for access on the rear mount as this is a little fiddly). Changing the front one should be your priority one though as this will make loads of difference to the way the car drives.
