Author Topic: replacing a u.j. on a mk2/mk3 help  (Read 3240 times)
Offline *tell*
« on: 09 April 2010, 19:41 »
mate has a MK2 vr6 with mk3 subframe.
i need to replace the universal joint on it do i need to drop the
subframe to do it?
thanks tell
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
Re: replacing a u.j. on a mk2/mk3 help
« Reply #1 on: 09 April 2010, 20:26 »
I am doing the same part at the moment on my mk2 vr you can do it without dropping the subframe
but its a bit tricky I undid the bolt holding the uj onto the rack and a bolt inside the car and used a flat screw driver
to lever it up on the rack
just make sure you line the hole up spot on with the spline
if the engines out i would drop the frame slightly my engines in could not be bothered taking it back out
Offline *tell*
« Reply #2 on: 09 April 2010, 20:35 »
cool thats wot i was thinking. the new u.j. i have is in two parts with a nut and bolt
going though the middle. with the nut and bolt out it may go in better (it will be shorter).
it a vw one off a passat vr6 (as was the steering rack). will be trying to get this done
tomorrow for gti fest on sunday.
Offline *tell*
« Reply #3 on: 10 April 2010, 23:28 »
done it today took a hour and a half.
i undone the steering column made it alot easier  :smiley:
