Golf mk4
Wazzzer
please help....
Topic: please help.... (Read 864 times)
ade_aidy_ady
GTI forum regular
please help....
09 April 2010, 16:10 »
got a bad misfire this morning.... checked plugs and they werent too good (over the 0.8mm recommendation) so new ones going in tomorrow....but i also did a scan on vagcom and it brought up the lambda sensor malfunction...
would a bad misfire from the spark plugs cause the lambda fault to show on vagcom or has this maybe gone faulty too...?
another question is when cleaning the MAF is it ok to just squirt the electrical contact cleaner through the plastic mesh on the MAF......?
thanks ......
Adrian
ade_aidy_ady
GTI forum regular
Re: please help....
09 April 2010, 18:42 »
anyone.... ?
matping
Here all the time
MK1 20vT MK5 GTI T
Re: please help....
09 April 2010, 18:46 »
before you put your new plugs in pal erase the code put the new plugs in then re scan after a few days
not too sure about the maff sensor tho pal
kcolevol
Guest
Re: please help....
09 April 2010, 18:48 »
I used carb/brake cleaner on my maf, worked mine, had a black hand afterwards tho but just showed the amount of crap it had in there
matping
Here all the time
MK1 20vT MK5 GTI T
Re: please help....
09 April 2010, 18:50 »
yea id go for that idea as carb / brake cleaner evaperates straight away !!
Golf mk4
Wazzzer
please help....
