Author Topic: front suspension problem  (Read 1401 times)
Offline Scooterist007
« on: 21 November 2004, 16:48 »
Hi to all you guru's out there!  8)
I have this problem, I have just changed the suspension on my wifes 97 gti, the rear shocks were gone so she bought a complete set of lowered springs and uprated shocks, now i have fitted them but, the front strut top has a lot of play in them, with the car jacked up, i can lift the wheel up about 5-10 mm, but everything is tightened down properly,now this shouldnt be like this! so would packing it  with a few washers be accecptable or is there somthing else i should do?
many thanks for reading
mrwotto
Re: front suspension problem
« Reply #1 on: 21 November 2004, 17:04 »
did you fit the bump stops ????
« Reply #2 on: 21 November 2004, 17:18 »
are the bump stops the rubbery/foamy type thingys that are on the suspension shaft underneath the gator/cover??
I put everything that was on the original suspension onto the new suspension in excactly the same order it came off.
mrwotto
« Reply #3 on: 21 November 2004, 17:21 »
yes mate they are, not really up on suspension i got a mate who hasa garage to ower mine for me, maybe worth taking it to a garagr matey or see if any one else can help or try posting same problem in the garage
sorry cant be of any more help
mrwotto
