Author Topic: Jack stands Positons for Rear  (Read 1318 times)
Offline jonesltd
  • MK7 R
« on: 09 April 2010, 10:22 »
As the tin says, I am wondering where I need to put the jack stands/axle stands so I can take both my back wheels off....Any pics pls...Thank you
If you cant find it......Grind it
Offline Steve_PD
Re: Jack stands Positons for Rear
« Reply #1 on: 09 April 2010, 10:27 »
on the rear beam
Offline jonesltd
  • MK7 R
« Reply #2 on: 09 April 2010, 10:28 »
Thanks...the beam that I used for the front but follow it to the back just before the back wheels?
Offline Steve_PD
« Reply #3 on: 09 April 2010, 10:39 »
you could put them on the chassis rail (what you put them on at the front) or when you jack it up look where the wheels are there is a beam going from passenger to drivers side put them on there
Offline jonesltd
  • MK7 R
« Reply #4 on: 09 April 2010, 10:42 »
Ok will try and have a go as I wanna sand me back wheels and was told just jacking it up isnt safe? Have put car up on axle stands before for the front just never for the back hence the questions
Offline jonesltd
  • MK7 R
« Reply #5 on: 09 April 2010, 11:17 »
Nope must be blind! Am lookin at the back and yes I can jack it up but cannot find a place to put the axle stands, nothing at the back is in the form of the front where I would put the stands  :sad: Everything at the back seems a lot flatter and wider and doesnt look like it will take an axle stand? My axle stand looks like an upside down bridge with lips either side ie where I could put them for the fronts...
