Author Topic: 1.8t timing chain tensioner rattle  (Read 2235 times)
Offline richard s
« on: 08 April 2010, 21:10 »
i have a 1.8t passat and the timing chain has been rattling so i changed the tensioner and did an oil and filter change today
and it still rattles  :cry:
the rattle is between 1600 and 2600 rpm when revving then clears till you let off and as the revs drop they return around 2600 rpm down to 1600 rpm then it goes again
has anyone changed their tensioner and did yours quieten down straight away or does it take a while
or is it the chain thats knackered
cheers
Offline Purely VAG
Re: 1.8t timing chain tensioner rattle
« Reply #1 on: 09 April 2010, 14:18 »
What engine code?
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline richard s
« Reply #2 on: 09 April 2010, 15:02 »
engine code is aeb
Offline Purely VAG
« Reply #3 on: 09 April 2010, 15:20 »
You mean the cam chain tensioner then? As they use Timing belt for cam --> crank timing.
Offline richard s
« Reply #4 on: 09 April 2010, 15:31 »
yes mate thats what i meant dont know why i called it the timing chain
i should have remembered what it was called as its been sat on side in kitchen for weeks staring at me and it took long enough to fit
