Author Topic: rattle noise  (Read 1323 times)
Offline ash1.8T
rattle noise
« on: 07 April 2010, 19:53 »
hi guys
my 1.8t (aum) has started to develop a deep rattle noise when the engine is warm and at idle it goes away with any revs :sad:. it sounds like its coming from the around the back part of the engine bay or under the engine cover. i took it to a garage to find out what it was and the guy said that the sound could be a bad case of tappets. he reckons a service will cure it as my car is due for one anyway.
im completely baffeled hope its not serious
has any of you guys had any tappet problems? if so how was it sorted
thanks in advance ash
Offline richw911
Re: rattle noise
« Reply #1 on: 07 April 2010, 19:54 »
Enough Oil in it? Correct oil?  :undecided:
Offline ash1.8T
Re: rattle noise
« Reply #2 on: 07 April 2010, 20:20 »
i believe im using the right oil its what was recomended on here lol
as for oil level it was abit low but not below the min so i jus topped it a lil bit
Offline richw911
Re: rattle noise
« Reply #3 on: 07 April 2010, 20:24 »
What oil are you using? How many miles has it done?
Offline ash1.8T
Re: rattle noise
« Reply #4 on: 07 April 2010, 22:05 »
castrol magnatec 15w 40
my car has done 109,000 miles
Offline james2
  • No scammers please.
Re: rattle noise
« Reply #5 on: 07 April 2010, 23:48 »
go for 10w 40 magnitec...
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline ash1.8T
Re: rattle noise
« Reply #6 on: 08 April 2010, 00:51 »
thanks buddy
 will use 10w 40 once ive put the car thu a service. the service should stop the tappets frm making a noise shouldnt it?
Offline Ben_1uk
Re: rattle noise
« Reply #7 on: 08 April 2010, 15:33 »
Quote
Tappets is engine oil related so in theory, a full service, ie new oil filter and oil change, should do the trick.
Powered by the fuel of satan!
Offline ash1.8T
Re: rattle noise
« Reply #8 on: 08 April 2010, 18:04 »
thanks ben
cheers for ur help guys  :grin:
Offline ash1.8T
Re: rattle noise
« Reply #9 on: 09 April 2010, 15:42 »
ive done abit of reading around some 1.8t have the same sound and it was fixed by replacing the cam chain tensioner could the same be done for my car if so any ideas on how much?  :grin:
