Author Topic: A stressful day....  (Read 3033 times)
Offline T_J_G
A stressful day....
« on: 07 April 2010, 19:50 »
Wanted to fit my 312mm front brakes and new rear discs and pads today. But the 312mm carriers haven't turned up so decided to just sort the rears for now. It seems the carriers are lost in transit somewhere...
What a pig of a job, the new pads didn't come with these little metal clips that on one side kept falling off and made it near IMPOSSIBLE to fit the pads in. Took about 5 hours to do the whole job with the other side taking about 30 minutes. It was chucking it down all day and very wet.  :sad:
Meanwhile I tried to find my leak, the bonnet release grommit was fine so reinstalled it and used a lot of silicone so around it so I can rule that out.
Fitted my new wipers while I was at it, a great improvement. So quiet and efficient. Happy days!
Old discs  :lipsrsealed:
New wipers:
And I'm left with a car that won't rev below 1300 RPM.... :undecided:
Offline navmk4gti
Re: A stressful day....
« Reply #1 on: 07 April 2010, 19:54 »
seems like you had a mk4 day mate  :lipsrsealed:.. why wont it rev below 1300 RPM.. good u changed the discs your old ones are fooked ..hope your carriers come too just keep chasing em up  :wink:
gotta change my pads next week.. not looking forward to it ..as i know im gonna find somehting else needs replacing :grin:
Offline richw911
« Reply #2 on: 07 April 2010, 19:56 »
Aeros FTW  :laugh:
Do you mean it wont idle?
Offline T_J_G
« Reply #3 on: 07 April 2010, 19:57 »
It sits steady at 1300 an takes a while to come back down if you rev it. I'll investigate firther in the morning. I've only just dried off.
Hopefully carriers will be here tomorow. Yeah the old discs were ready to be binned.
Offline navmk4gti
« Reply #4 on: 07 April 2010, 20:02 »
mines been doing that too.. but it does it after a very very long drive or hard booting it and then the revs stick at about 1100 rpm den drop once i rev it sligtly.. happens few tyms den goes away its self  :undecided:
Offline T_J_G
« Reply #5 on: 08 April 2010, 13:37 »
Still idling at 1300 but running fine, no codes.
MAF?
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #6 on: 08 April 2010, 15:05 »
Temp sensor?.... Any fault codes?
Offline Ben_1uk
« Reply #7 on: 08 April 2010, 15:22 »
Any problems starting it?
Powered by the fuel of satan!
Offline T_J_G
« Reply #8 on: 08 April 2010, 16:29 »
No problems starting it, temp sender is near brand new.
Offline Ben_1uk
« Reply #9 on: 08 April 2010, 16:31 »
Quote
That's that then!
