Author Topic: Airbag light resistor £30 from vw, any alternatives???  (Read 6279 times)
Offline Leroy
  • Golf GTI Anniversary 16v
As above, going to fit my momo wheel, dont want the airbag light on, searched the site and got an answer and the part number, rang vw and its £30 odd???
The guy from vw said you only need the resistor but from them its the whole kit.
Has anyone got a cheap fix? maplins jobby or something???
Re: Airbag light resistor £30 from vw, any alternatives???
« Reply #1 on: 07 April 2010, 13:29 »
Have you tried Momo
Offline vwscottie
« Reply #2 on: 07 April 2010, 13:58 »
The later mk3 golf which has a drivers airbag  has a resister behind the glove box if it doesn't have a passenger airbag fitted. You will have to remove the glove box to be able to get to it, then its a case of just unplugging it
Offline kr1s77
« Reply #3 on: 07 April 2010, 23:48 »
Hi, I used a 0.33 ohms resister I obtained from my old workplace and it did the trick. I think u can get them from maplins
ASV 1.9 TDI 110
Offline Adam
« Reply #4 on: 08 April 2010, 12:12 »
I used a 3.3 ohms :huh:
Down Hill From Here.
Offline kr1s77
« Reply #5 on: 08 April 2010, 12:29 »
Lol that's what I meant, a 3.3 ohms
ASV 1.9 TDI 110
Offline Leroy
« Reply #6 on: 08 April 2010, 13:24 »
cheers guys, is it just a case of plugging into the wire which feeds the airbag?
Offline Adam
« Reply #7 on: 08 April 2010, 13:29 »
Pritty much yeah.
Offline kr1s77
« Reply #8 on: 08 April 2010, 17:46 »
I fitted it to the connecter that connects to the slip ring in the cowling.
ASV 1.9 TDI 110
Retro_look
« Reply #9 on: 27 February 2011, 16:04 »
guys, is it a 3.3k ohms or a 3.3m ohms resister needed for this job?
