Author Topic: vag com and windows 7  (Read 11809 times)
Offline northeast_gti-t
  • "1.8T AGU"
« on: 06 April 2010, 18:43 »
Well probably been asked a million times but now i'm just about f***king fed up with my laptop and windows 7 i have installed vag com 409 and the required drivers for an e-gay lead set it as per running it on vista as in windows service pack 2 administrator etc and click on it to open/run it and nothing!!! does not open and now im getting fed up  :angry: :angry: :angry: :angry: anyone shed some info for me pls before i chuck this f****ing laptop through a window!!!!
2000 Mkiv GTi 1.8T AGU
Offline mowlamb
  • MK4 GT TDI 130 - DERV POWER!!
Re: vag com and windows 7
« Reply #1 on: 06 April 2010, 20:46 »
I've had the same problems mate, Adam says he has his working on windows 7 so I'm trying one last time else I'm getting a handheld scanner.
Offline mowlamb
« Reply #2 on: 06 April 2010, 21:20 »
Just tried re-installing mine and the same as you mate. Folowed the step by step guide that came on the disk with the drivers and now the program won't even open. 409.1 is what I got. Is that the right one?
  • "1.8T AGU"
« Reply #3 on: 06 April 2010, 21:25 »
thats the one yep 409.1
Offline Jay
  • balding fat cvnt
« Reply #4 on: 06 April 2010, 21:44 »
Double check that you've installed 409.1s NOT 409.1us - the S stands for serial (which the ebay cables are, despite them using a USB connector they have serial->USB converter in the ODB2 connector) and the US stands for USB, which only the real Ross Tech cables will work with.
Offline mowlamb
« Reply #5 on: 06 April 2010, 21:46 »
That wouldn't stop the program from opening tho, would it?
Offline Jay
  • balding fat cvnt
« Reply #6 on: 06 April 2010, 21:50 »
I found on 1 of my laptops installing / uninstalling VAG COM and drivers a bit stopped it from opening.
Uninstall that version, and reinstall to a different location.
  • "1.8T AGU"
« Reply #7 on: 06 April 2010, 22:10 »
i just looked in my programs part for install/uninstall and no vagcom listed  :huh:
Offline Jay
  • balding fat cvnt
« Reply #8 on: 07 April 2010, 12:37 »
Just delete it  :grin:
Offline Voodoo-Music
« Reply #9 on: 12 April 2010, 22:34 »
have you tried running it in compatability mode, also if your running a version that your not supposed to you have to enable administrator permissions to the batch file
not that im running one of those versions, im just a software coder  :wink:
