Author Topic: Vag com  (Read 7367 times)
Offline ian007miles
Vag com
« on: 05 April 2010, 13:03 »
I've just tryed my vagcom for the first time, but I can't get it to work can some one tell me how to Load it up and get the fault codes up please thanx ian                 it keeps saying no response from controller
« Last Edit: 05 April 2010, 13:17 by ian007miles »
Agu|k03s|forge 007 dv|forge boost pipes|forge water pipes|forge tip|forge kona cold air intake|milltex 3" down pipe sports cat|milltek cat back exhaust|r-tech custom remap 238bhp and 235 torque
Offline topher
  • Administrator
  • fully functioning
Re: Vag com
« Reply #1 on: 05 April 2010, 13:20 »
is your ignition on? :lipsrsealed:
Offline ian007miles
Re: Vag com
« Reply #2 on: 05 April 2010, 13:21 »
yes it on
Offline topher
  • Administrator
  • fully functioning
Re: Vag com
« Reply #3 on: 05 April 2010, 13:22 »
probably something in the com port settings then.. in options on the main screen
Offline ian007miles
Re: Vag com
« Reply #4 on: 05 April 2010, 13:23 »
talk me through it if u can mate  :smiley:
Offline topher
  • Administrator
  • fully functioning
Re: Vag com
« Reply #5 on: 05 April 2010, 13:24 »
no idea, mine worked right out of the box - i got ryan's working by trying different com ports, i think we went with 4 in the end for his.
Offline ian007miles
Re: Vag com
« Reply #6 on: 05 April 2010, 13:32 »
Com port 3 is the only one working and then there is loads of other numbers in diferent boxes do u no wot the numbers should be on?
Offline ian007miles
Re: Vag com
« Reply #7 on: 05 April 2010, 13:49 »
I've just clicked on the oBD-11 button and it says that car is not iso/obd compatible! And says try select-> individual controllers, but I don't no were to do this
Offline topher
  • Administrator
  • fully functioning
Re: Vag com
« Reply #8 on: 05 April 2010, 13:57 »
the obd2 function is just for generic codes - you use that if you want to pull codes from a non-vag car
it's either something in the connection/port settings or a duff cable
Offline Jay
  • balding fat cvnt
Re: Vag com
« Reply #9 on: 05 April 2010, 14:09 »
I should really write up a complete VAG COM FAQ/How to make it work so people don't need to keep asking the same questions  :grin:
