Author Topic: What coolant?  (Read 2043 times)
Offline Stitch
Re: What coolant?
« Reply #10 on: 06 April 2010, 20:41 »
If its a little below the top marker its fine. It will find a level somewere between that. Mine is nearer the lower marker than top and is fine. You probs find you will top it up and it will just go back down to level it was at.
Offline TrickGTI
Re: What coolant?
« Reply #11 on: 10 April 2010, 18:36 »
Make sure to check the level when cold as the level will change slightly with the temp of the engine.
